#1 Posted : Tuesday, 4 April 2006 8:30:40 AM(UTC)
HI, I would like some information as to what model Holden the following triple crankshaft pulleys belong. (A) All three vees side by side and touching. (B) Two vees close to harmonic balancer side by side then a space and then another vee. (C) One vee close to balancer then a space and then two vees side by side. I have seen (A) on a 253/308 HG with factory A/C and I think the Commodore is the same and (B)is on the HQ-WB range but I have no idea what model (C) has come off of. I saw one at a swap meet with the rest of the stuff needed for a HQ-WB pwr str conversion but I thought this cannot be the right pulley for this conversion because the fan belt vee is now running in a different spot to standard?? Your information will be appreciated. Cheers TD
#2 Posted : Tuesday, 4 April 2006 5:40:44 PM(UTC)
B is a HQ-WB if memory serves me correct (inner is steer, centre is fan, outer is A/C). Also if memory is correct, VB-VL have all pulleys side by side but spaced out from the balancer by a small amount (basically by a belt width). I think you are correct
classic oz wreck Offline
#3 Posted : Wednesday, 5 April 2006 8:26:33 AM(UTC)
classic oz wreck
A is hq to wb...
www.classicozwreck.com.au
#4 Posted : Wednesday, 5 April 2006 7:07:00 PM(UTC)
I had a look last night and Greg is correct - A is HQ-WB. B is possibly an aftermarket HQ-WB.
#5 Posted : Thursday, 6 April 2006 7:09:42 AM(UTC)
classic oz wreck
b reminds me of power steer and alternator with the outer pulley for aftermarket a/c for hq to wb...the outer should just slide out of the inner...
#6 Posted : Friday, 7 April 2006 5:13:37 AM(UTC)
I will try and get a picture because I have found that I have all three pulleys. (A) was definately the same as the one on my HG with factory A/C and Steer and (B) is the same as on my HZ Tonner and WB Statesman but I have no idea where (C) belongs. With
