#1 Posted : Wednesday, 5 April 2006 9:03:22 PM(UTC)
Hello Again,
Could someone please tell me what the front of an HX Premier had as far as Badging and Paraphernalia, and where they were located, If my memory serves me correctly, the Kingswoods had the badges just in front of the front door, and the Premiers had them just behind the front clip, is this correct? and if so what are the measurements from the clip and from the top and bottom etc. Also did the Premiers have a bonnet ornament or was that only the Statesman? and what about the grille badges? , I know there is a slight difference in the HJ HX and HZ as to where the grille gadges were located, so if anybody can fill me in on all this stuff that would be great,Thanks for any advice.
Todd
P.S. I got the 308 in and the front springs seem to be handling the extra weight OK.
#2 Posted : Thursday, 6 April 2006 12:05:18 AM(UTC)
HI Todd.
The Premier badge on the HX front guard is in the same spot as the Kingswood badge. The badge itself is also unique to the HX, i.e. different to HJ & HZ. The grille badge is the large lion in the centre, the same as that on an HX Kingswood.
#3 Posted : Thursday, 6 April 2006 5:57:09 PM(UTC)
Dr Terry , you might want to have a look in your own book reguarding the grille badge, as the premier is different to the kingswood , it is rectangle with a small lion and pattern the same as rear pillar badge.
#4 Posted : Thursday, 6 April 2006 7:34:08 PM(UTC)
Hi Guys.
Thanks cloudy, my mistake, the HX Premier grille is the same as the HX Kingswood, but the Premier grille badge is the same small rectangular badge as the HJ Premier.
Dr Terry.
