#1 Posted : Sunday, 9 April 2006 3:20:53 AM(UTC)
I have an EA 3.9 multi point Falcon, My problem is, after car has been running and then left for 1 to 2 hours it is hard to start, motor cranks but wont fire, it sounds like it is running on 2 cylinders. With persistance it will fire & it blows black smoke out of exhaust and will blow light grey smoke out of air box.
Mechanic has replaced plugs ,leads and fuel filter.
Auto elect has replaced ignition coil and map sensor and still the problem is there. If car has been standing overnight it does not give trouble nor if you start car up within 30 minutes of switching off.
Does anyone have any clues as to what may be going on.It is if auto choke is on.
Many thanks
XB351 Offline
#2 Posted : Monday, 10 April 2006 9:33:21 PM(UTC)
XB351
check your Air flow meter and O2 sensor works
#3 Posted : Tuesday, 11 April 2006 8:31:28 AM(UTC)
unplug your battery and then unplug your computer for a couple of hours try that. i put a new map sensor in a eb and it keep doing the same thing so i unplug the computer and left it for a couple of hours. the computeris placed behind the kick panel on th
#4 Posted : Wednesday, 12 April 2006 9:35:20 AM(UTC)
sounds basic I know, but check the operation of the PCV valve ...
#5 Posted : Thursday, 13 April 2006 12:25:45 AM(UTC)
EA falcons do not have air flow sensors, they use map sensors. It may be leaking injectors or a faulty fuel pressure regulator. Connect a pressure gauge into fuel system and test fuel pressure when engine is turned off.
#6 Posted : Thursday, 13 April 2006 8:03:58 AM(UTC)
Check the coolant tempreture sensor,this richens the mixture when car is cold for easier starting,but when faulty will flood car when engine is hot.
if it ain't broke we can improve it.
Cheers Steve
#7 Posted : Saturday, 30 June 2007 4:28:58 AM(UTC)
Make sure that your fuel pressure regulator is not leaking fuel into inlet manifold through the vacuum line
