RussVRute Offline
#1 Posted : Friday, 14 April 2006 11:33:47 PM(UTC)
RussVRute
G'day all,
I need to take my pitman arm to remove my steering box for replacement as it is leaking like crazy, and the tie rod ends are not that old so dont want to have to change that end of the pitman arm, so I figured I could just take the pitman arm off the steering box but I cant get it to budge, what sort of puller do you use for this, as I'm no mechanic, but know enough to know there are different types of pullers, so which one do I use?Any help greatly appreciated.
Cheers.Russ.
#2 Posted : Saturday, 15 April 2006 5:38:25 AM(UTC)
Russ,
You need to get yourself a "pitman arm puller" - a proper auto shop, sometimes even supercheap will have these on the shelf. Around $20. There are two main types - the wedge type that is similar to what you can use for tie-rod ends (hammer the we
BrianH Offline
#3 Posted : Saturday, 15 April 2006 8:34:16 AM(UTC)
BrianH
Russ
Back in the days when I was a bright eyed little apprentice working for a Sydney Holden dealer in the EJ, EH days, the mechanics in the work shop had a special tool for removing pitman arms. It was piece of water pipe about a metre long. You ope
