#1 Posted : Sunday, 25 February 2007 10:57:01 PM(UTC)
hello out there,
I am tryin to put an aussie 4 on the floor into my tree manual hr, had to cut the cross member, what is needed to engineer, is it possible to fit without the auto tunnel conversion, have heard both yes and no for this problem........
thanks
garrick
#2 Posted : Saturday, 3 March 2007 7:35:49 PM(UTC)
I put a all aussie in to my HR and I had to cut thru the main floor support and rebrace it. I used an auto crossmember and auto tailshaft and fitted a tonner clutch and changed the speedo cable. It bolted straight in. If you use a shifter which has the th
