#1 Posted : Tuesday, 18 April 2006 3:33:27 AM(UTC)
I'm experiencing probs with Smartlock on my EB. Seems to be time or temperature related. Remote works fine when car hasn't run for a while. When car is "warm" the accessories relay seems to stick (fan runs when key is off and removed) and the Smartlock wont engage (light wont flash and the remote wont operate locks. After a long period (provided all accessories are turned off) the Smartlock starts operating again and remote works. If operated and the engine is only run momentarily there doesn't appear to be a problem giving me the impression that it is maybe computer temperature related. I have re-programmed the remote successfully and also battery off to reset the ECM. Any help appreciated.
bg
stu Offline
#2 Posted : Tuesday, 18 April 2006 6:47:56 AM(UTC)
stu
i have owned 3 eb falcons.
your ignition or key sounds stuffed.have you jump started a car lately or shorted the battery as you have to put the negative on the block to avoid computer probs.i have had ignition trouble with smartlock.i sprayed wd 40 in ig
stu
#3 Posted : Tuesday, 18 April 2006 9:35:20 PM(UTC)
Ouch!!
Thanks Stu
#4 Posted : Wednesday, 19 April 2006 2:44:52 AM(UTC)
I seem to remember in my Fuzzy memory when they were new one of the fixes was to leave the car standing with the ignition on for about 90 minutes to reset the Smartlock.
#5 Posted : Wednesday, 19 April 2006 9:15:09 PM(UTC)
THanks Jim, I'll give it a a try
#6 Posted : Thursday, 20 April 2006 8:32:13 AM(UTC)
Unfortunately neither of the suggestions have worked on this one. Sounds like an Auto Elec'n job.
bg
#7 Posted : Wednesday, 7 June 2006 9:44:46 AM(UTC)
Well I finally got it beat. Seems that if I have my rechargeable torch in the cigarette lighter the voltage present stops the Smartlock from activating. Over a very long time that voltage must seep away and activation occurs - hence the apparent temperatu
