Coolngroovy.
Sure would be interested in Tags and other bits. I can be contacted on 0405186344.
Regards Rockett.
Rockett,sorry it took me a while, you should contact the owner direct.His name is Alan at Burnett Motor Trimmers. Mackay QLD. 0749 576783. I think he still has them.
coolngroovy.
Thanks mate Ill give him a call.
Regards Rockett
coolngroovy.
Thanks mate I'll give him a call.
Regards Rockett
I also have a HJ GTS coupe with missing ID plates. I have the chassis number. Can the correct VIN be cross referenced against this number. Thanks
Byron, you mentioned you may have access to microfisch information. Of course i have the body no, can this be used ? I have tried to track previous owners to determine why the plates are missing, without any luck. I also contacted department of motor re
where can i get a blank gmh body id plate as mine is missing you can email me on [email protected]
GM-H do not issue blank plates, you would have to know someone in the factory to get one "smuggled" out. They did not even re-issue/stamp the ones they made mistakes on. You often come across a car that has a typo stamped over.
Even if you could get on
i know this is a bit out feild ,, but im looking for a hq annerversary dash , im restoring a 253,trimatic(colum shift) premier , with p/s a/c . its apperently a factory 253,auto,p/s a/c premier annerversary model ,,, how can i tell if its a genuine anne
here is the item number of one that sold on ebay recently
200056819331
The HQ anniversary model came in one colour and trim combo, so you trim line should be the same as the tag shown.
trim 1903 35R
If a Brisbane build it will show the AVR for
G'day to all does this number make sense to any one.... vhj23603b???
Gday to all does this number make sense to any one.... vhj23603b???
v should be an A or B.
Thanks Byron, thats what i wanted to hear, I didnt hear him proply obviously:)Looks like i got me self an orignal (mathing numbers) hj gts sedan.
Thanks Byron, thats what i wanted to hear, I didn't hear him proply obviously:)Looks like i got me self an orignal (mathing numbers) hj gts sedan.
quote: Originally posted by Byron Rich there were only 606 HJ GTS coupes made, and probably only 20 or so in february 1976.
4/76 HJ monaroGTS |
I have a HJ GTS 4 door that is a 76 model. It is missing the ID plate. However, I have all the other original information including chassis, compliance, body number, and even the engine number I think!! Can anyone tell me whether I can get hold of the wha
What ID plates do you have?
What id plates do you want to find the number to?
Warren
I have the Body Id Plate, Safety Compliance Plate, Chassis Number, and I think an Original Engine Number. The Vehicle Identification Plate was lost. Is there any way of finding out what the vehicle identification plate number is? It is a genuine GTS four
