hi i have a vr commodore ,i need to know which color wire at the coil regulator is the active one to cut into to cut off the spark to allow fuel to go down the line.
cutting spark to pump raw fuel through the motor will achieve 2 things:
1. It will very quickly kill the CAT convertor (and you will lose a lot of performance & suck heaps of fuel)
2. It will wash the oil off the cylinder walls, creating score marks |
I did the choke/ key off, pump pump pump, key on trick in my EH when I first got it. I quickly learned after about 10 goes that it just wasn't worth it as my muffler opened like a split sausage.
Personally in my own opinion, I like cars to be cruised, |
Presumably you will be able to sleep after you have started the next major bushfire and burned a few people out of house and home and a few thousand hectares..
