#1 Posted : Wednesday, 19 April 2006 5:57:41 AM(UTC)
my ed 4 speed shifts smoothly sometimes and very rough and jerky other times , i serviced it which only made the jerky shifts slightly better, could this be the kickdown solonoid
#2 Posted : Friday, 21 April 2006 8:47:35 AM(UTC)
Sounds like the S5 solanoid, this solanoid is a variable pressure solanoid. This is the largest solanoid in the trans.This is the most common problem.It could also be a shift solanoid,gear position switch,Valve body warped,throtle position switch,dirty wi
#3 Posted : Tuesday, 2 May 2006 9:56:13 PM(UTC)
turned out to be s5 should i reset ecu by disconnecting battery or is it not needed.
This page was generated in 0.127 seconds.
