#1 Posted : Friday, 21 April 2006 2:19:43 AM(UTC)
hi just need 2 know i have 2 gts dashes 1 out of a 6 cyl and 1 out of 8 is there any diffrent to the wiring set up i know the gauges are a little diff eg.the 6 dash tacho has aneedle u can set for rev range and is in mph. the 8 dash is in mph and kms can the 6 go straight into 8 please help these are ht gts dashes
#2 Posted : Friday, 21 April 2006 2:57:10 AM(UTC)
Hi htv8coupe.
The instrument assemblies are the same between 6 & V8, there should be a small switch to change the tacho from 6 to V8. All the gauges are the same.
The difference with the extra needle rev pointer is that HT have it & HG don't.
The
#3 Posted : Friday, 21 April 2006 4:34:30 PM(UTC)
thanks for the info just 1 more Q were is this switch for the tacho 2 change it and do all gts dashes have it
#4 Posted : Saturday, 22 April 2006 10:12:45 AM(UTC)
The switch (from very vague memory) is down towards the bottom of the tacho, literally on the rear of the housing. It is just a little black slidebar with some serrations on it so you can hook your fingernail into them to change the tacho from 6 to 8 cyl
Edited by user Saturday, 22 April 2006 10:13:26 AM(UTC)  | Reason: Not specified
#5 Posted : Saturday, 22 April 2006 4:56:45 PM(UTC)
hi dave thanks 4 that i found it mines white and round and its marked it was a little hard 2 c but cleaned up now u can see it thankyou guys for your help
