Handgunner Offline
#1 Posted : Saturday, 22 April 2006 9:21:30 AM(UTC)
Handgunner
Hello everyone :-),
I would like to know what i should do here in regards to fitting a Column shift auto to what was a 3 on the tree column, and also what linkages can i use for running a chev with either a glide or a th 350 / 400....do i have to get the specific ones for the box i choose, eg turbo 350 ( linkages from Monaro, or were they just t bars? ) or glide ( just any old HKTG linkages from your typical sedan? The cheaper option would be good for me as i am on a tight budget..Please help as i havent got a clue lol, im just a newbie...so ant info would be great ! Thanks a lot ,
Anthony
Bang Bang
Bang Bang
Duzty Offline
#2 Posted : Saturday, 22 April 2006 4:28:58 PM(UTC)
Duzty
i would go a B&M shifter much more fun.
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop online directly from
#3 Posted : Saturday, 22 April 2006 10:56:29 PM(UTC)
Powerglides came out standard behind a 307 with a column shift in HK and early HT. Simply find a V8 auto column shift example and get the column and linkages. The box is shifted with a crossover mechanism under the box. Has to be a V8 setup though as the
Edited by user Saturday, 22 April 2006 10:59:37 PM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 23 April 2006 12:59:40 AM(UTC)
Thank you for that , thats exactly what i needed to know !
And yes , to the previous posted message , a Quicksilver would be good fun, i am just trying to do the easiest set up and see what options i have :-).....Cheers to Everyone..
Cya all...
#5 Posted : Sunday, 23 April 2006 4:28:59 AM(UTC)
If you play around with it a little you may even be able to adapt the powerglide mechanism to a TH350 using a column shift trimatic column out of a HT or HG.
Sandman Offline
#6 Posted : Sunday, 23 April 2006 5:44:56 AM(UTC)
Sandman
If your going to have a bit of fun and do a bit of thrashing, I'd go for a B&M shifter.
1. It has a reverse lockout.(Old column shifts easily go past D and into N or R when your shifting manually)Gets really interesting if you get reverse!!!
2. Cable sh
Sandman Offline
#7 Posted : Sunday, 23 April 2006 5:47:22 AM(UTC)
Sandman
PS. I've got an old HQ T bar shifter somewhere to suit a TH400. You can have it for a carton of beer if you want. Plus postage.
This page was generated in 0.080 seconds.
