Jvanner Offline
#1 Posted : Sunday, 23 April 2006 3:15:12 AM(UTC)
Jvanner
Hey Fellas. The fan on my HZ only works on 1 speed. but the bad things it only works on low. is it possible to fix so all the speeds work and i can demist my front window.
#2 Posted : Sunday, 23 April 2006 4:17:32 AM(UTC)
the cheats way off getting round it is to get a cheap on/off switch and wire it to the high speed wire on the fan motor. there are three wires and the black wire is the earth. get a power feed (fused) wire and wire it through the switch to the motor, you
peterwmh Offline
#3 Posted : Sunday, 23 April 2006 7:04:43 AM(UTC)
peterwmh
It'll be the dash switch if it's the standard 2 speed heater fan. I have a spare I can sell you, $10 + postage will get it. Drop me a reply with your email address if you're interested. If it's a factory air fan (4 or 5 speed), then you'll need the res
Jvanner Offline
#4 Posted : Sunday, 23 April 2006 5:52:58 PM(UTC)
Jvanner
Thanks for your help fellas. Peter, thanks for the offer. but mine is the 4 speed a/c switch,as im going to try to get an after market a/c unit for it and get it hooked up to the factory dash switches.
chopperz Inc Offline
#5 Posted : Monday, 24 April 2006 10:59:58 AM(UTC)
chopperz Inc
Check the earth wire on the fan motor for a clean contact, abit of corrosion will slow it right down.
#6 Posted : Monday, 24 April 2006 5:57:14 PM(UTC)
The 4 speed fan has a set of resistors in the AC unit under the bonnet, seen from the passangers guard there sahll be a small plate with 2 screws, pull it out and check for all intact. (not likely to be the problem as it is normal for the other way speed
