#1 Posted : Tuesday, 2 May 2006 5:01:11 AM(UTC)
Does any one know were i can purchase some brake line clips from, they are the U shaped ones about 20mm wide 30mm long with a kink in the || parts of them coventrys and repco have been useless as usual
And also does any one have a holden genuine parts catalogue and can look up the part number for the flexiable brake hose/t peice the go's from the axcel to the body of a HZ statesman disc sailsbury diff
Glenn
#2 Posted : Tuesday, 2 May 2006 7:46:52 AM(UTC)
any wrecker should have the clips and I would not be surprised if other cars did not fit as well, like Falcon and Valiant.
The brass fitting you should also have no trouble getting from a wrecker it's not like they wear out. Or is it the flexible hose yo
#3 Posted : Tuesday, 2 May 2006 9:16:45 AM(UTC)
yeah the flexiable hose im after the part number for that and a place that sells the line clips
#4 Posted : Tuesday, 2 May 2006 12:12:26 PM(UTC)
Glenn,
2822916 is the hose part number for an HX (don't have an HZ book...) for all Sedans/wagons/coupes/Stato's. Of course HX's didn't have rear discs either.....
HTH
Cheers...Dave
#5 Posted : Tuesday, 2 May 2006 12:15:07 PM(UTC)
Try Holden for the Brake line clips. The senior Spare Parts guy at Goldy's in Midland seems to know his way around old Holdens....Ask for HQ and HJ and HX and HZ and WB as they may be interchangable but only 1 model's clips may be listed in their system a
Edited by user Tuesday, 2 May 2006 12:17:56 PM(UTC)  | Reason: Not specified
