Bluez Offline
#1 Posted : Friday, 5 May 2006 6:17:41 AM(UTC)
Bluez
GDay Guys
Put a post in buy and sell section to no avail..i am after the linkages for Chev to Powerglide kickdown. Does anyone know of an aftermarket version? because getting original ones seem to be a bit of a task? or maybe someone has them that doesnt need them. Its for my HK Monaro but im sure any will do as long as its from a 67 onwards car.
Paul
Jesse Jesse Jesse, you've not got a sense of humour!
#2 Posted : Friday, 5 May 2006 6:11:37 PM(UTC)
Most speed and auto shops will be able to get you an aftermarket cable kickdown. These were standard also on late HZ-mid WB and VC-VH also (cars with a TH350 that is) which you should be able to adapt.
Bluez Offline
#3 Posted : Friday, 5 May 2006 11:26:48 PM(UTC)
Bluez
Thanks Byron..ill check some out
