Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
GDay Guys Put a post in buy and sell section to no avail..i am after the linkages for Chev to Powerglide kickdown. Does anyone know of an aftermarket version? because getting original ones seem to be a bit of a task? or maybe someone has them that doesnt need them. Its for my HK Monaro but im sure any will do as long as its from a 67 onwards car. Cheers Paul |
Jesse Jesse Jesse, you've not got a sense of humour! |
Most speed and auto shops will be able to get you an aftermarket cable kickdown. These were standard also on late HZ-mid WB and VC-VH also (cars with a TH350 that is) which you should be able to adapt. |
Thanks Byron..ill check some out |
