#1 Posted : Sunday, 7 May 2006 11:14:51 AM(UTC)
Question for those air experts
Are air con driers interchangeable? Can I fit say a VN one to a HQ or other make system?
I dpn't see why not but there may be some technical reason.
Why I ask is you see them come up on EBay for different makes like Mazda or Suzuki or ford and wonder if they can be used on other models.
thanks.
#2 Posted : Sunday, 7 May 2006 8:58:04 PM(UTC)
The sealing system (flare or O-ring) the thread size & pitch, and the dessicant type (to suit various gasses) are usually all different, so you don't really know if it will fit unless you can look at it & try the threads.
_____________
#3 Posted : Monday, 8 May 2006 4:09:53 AM(UTC)
Thanks mate.
John
#4 Posted : Monday, 8 May 2006 4:11:16 AM(UTC)
Actually I guess one way out is to have new hoses made up with the right ends, most times you have to anyway.
#5 Posted : Tuesday, 9 May 2006 8:17:40 AM(UTC)
You are better off using one to suit that model they are very cheap to buy, around $10-$30. The problems u face using say a Vn one is it may not be a XH7 or XH9 dessicant type drier to suit R134a type gas. If u use a early model drier to suit R12 gas it
#6 Posted : Wednesday, 10 May 2006 7:43:27 AM(UTC)
Thanks Luke
