stumpy Offline
#1 Posted : Tuesday, 9 May 2006 6:45:33 AM(UTC)
stumpy
OK I GIVE UP. CAN ANYONE TELL ME HOW THIS COMES OUT OF THE DASH. IT,S DEAD SET GOT ME STUFFED???
classic oz wreck Offline
#2 Posted : Tuesday, 9 May 2006 7:41:52 AM(UTC)
classic oz wreck
first up,you must be able to put it in the accessory position....use an old choke cable and knob and cut it about an inch from the knob...insert the wire into the small hole and it will push down on the pin which releases the ignition barrell..its spring
www.classicozwreck.com.au
stumpy Offline
#3 Posted : Wednesday, 10 May 2006 4:08:22 PM(UTC)
stumpy
Sounds pretty simple, i will give it a go. Cheers
