greenhj Offline
#1 Posted : Friday, 12 May 2006 12:26:38 AM(UTC)
greenhj
I currently have two k+n breathers on my rocker covers. Engine is a Vn headed 355 making over 450 hp. Is this fine to vent blowby gas or should I run pcv setup. My concern is that the dirty air will compromise tune and affect performance.
greenhj
JBM Offline
#2 Posted : Friday, 12 May 2006 9:41:00 AM(UTC)
JBM
You could run a catch can with a filter between the valves and the manifold on the PCV system, the catch can would need to be airtight.
The PCV system just sucks the crankcase gases out using the manifold vacuum.
The K&N breathers will just spray oi
