laurence Offline
#1 Posted : Sunday, 14 May 2006 8:48:47 PM(UTC)
laurence
my hg brougham g/box to crossmember mount has standard mount under box then under crossmember it has rubber then steel plate that bolts pass thru is this standard as it needs replacing , and can find none listed at local auto one shop my manual does not show one either . also does anyone think it is better to replace f/end rubber bottem bushes with nolathane type mine have a habit of not lasting to long
Edited by user Sunday, 28 May 2006 5:26:37 PM(UTC)  | Reason: Not specified
laurence Offline
#2 Posted : Sunday, 14 May 2006 9:32:26 PM(UTC)
laurence
yes that mount is ok but what about rubber and steel that is fitted uder crossmember , bolts then pass tru it up into mount you pictured or has past owner done this for some reason?
#3 Posted : Sunday, 14 May 2006 10:04:15 PM(UTC)
if you can't find the original bottom plate just cut out a bit of 5mm steel plate (w/finished edges) and drill a couple of holes.
never seen rubber under there though(?)
there are no stupid questions, only stupid people
#4 Posted : Monday, 29 May 2006 5:32:34 PM(UTC)
Laurence
The rubber is part of the crossmember. You have to either find a good crossmember or what i did is use a HT crossmember which doesn't
have the rubber.They only changed to that crossmember in the HG ot make it smoother.If you have a bit of power
