#1 Posted : Wednesday, 17 May 2006 1:16:28 AM(UTC)
Hi,
I have just bought a pretty decent EJ for my girl and we are doing it up. Now we want to put in a 3.8 from a vn-p commodore and I have a couple questions that I was hoping that someone could answer for me.
I know that we have to convert to the HR front end which isnt a bad idea as we were thinking of buying the stub axles from v6 conversions to run commodore front brakes to go with the diff (ive found a good low km complete car for donor), but what I need to know is whether it is compulsory to change to the rack and pinion or can i stick with a steering box?
We are going to cut the tunnel out of the vn to suit the auto trans and put that into the EJ and then get the vn tailshaft cut down to suit the EJ so thats all pretty easy.
Are there any tricks to doing this conversion?? Im thinking of getting the readily converted crossmember to suit the v6 and by using all the vn bits im hoping that it will all go smoothly
Thanks in advance
Steve
peter_flane Offline
#2 Posted : Wednesday, 17 May 2006 1:24:26 AM(UTC)
peter_flane
The steering box wont fit with the V6 in there.
#3 Posted : Wednesday, 17 May 2006 2:56:08 AM(UTC)
Ok I can offer you a tip on the tailshaft. The Commodore item is a 2 piece unit that will need a new centre bearing mounted under your floor for the centre bearing.
However if you are using the Commodore diff the VN tailshaft uses the same uni j
#4 Posted : Wednesday, 17 May 2006 5:52:34 AM(UTC)
First hint, DON'T use the V6 conversion front brake kit!
The bolt that holds the brake hose to the calliper hits on the top suspension hat, you have to grind part of the hat away and then still weld a spacer to your steering stopper and will lose some f
#5 Posted : Wednesday, 17 May 2006 4:26:32 PM(UTC)
Originally posted by Jim5.0
Alternately if you are into blind faith & want to use the EJ's banjo diff I have been to
#6 Posted : Wednesday, 17 May 2006 7:49:09 PM(UTC)
Hi Guys.
Add to that list, Saginaw M21/M22, Aussie M15 & the Powerglide.
#7 Posted : Wednesday, 17 May 2006 8:07:34 PM(UTC)
& the dreaded Torquemaster I believe.
