#1 Posted : Wednesday, 17 May 2006 6:19:03 AM(UTC)
can any1 tell me i have 302 cleveland n i have fmx gearbox i had the hole motor in the car i couldnt start the car my brother said it maybe the gearbox can anyone tell me if i need too do anthing all i was getting clicks from the starter n no its not starter motor thats ****ed i pull it out n check buy using charge battery. thanx
r.cardilini
Paul351xb Offline
#2 Posted : Wednesday, 17 May 2006 9:11:32 AM(UTC)
Paul351xb
Need a bit more info mate. What's it in? Could be bad leads. Could be a crook cell in the battery. If it's XC look under the battery tray and you will see a big solenoid (or whatever the hell it's called } that the lead goes into. Could also be that.
#3 Posted : Wednesday, 17 May 2006 9:37:23 AM(UTC)
its in a xe ute 351 iam not even getting motor turn over i know the motor goes as i had it in the car i dunno if its the thing thats behind the torque converta maybe i have put it around the wrong way my uncle was saying maybe i have put the gear box in t
steadyeddy Offline
#4 Posted : Tuesday, 14 November 2006 1:24:37 AM(UTC)
steadyeddy
Madexy i'm pretty sure when you fitted the tranny you didnt line the torque converter to gearbox properly, they only fit in one position, if they don't you will get lock up
Cheers Ed.
Guest (5)
This page was generated in 0.128 seconds.
