#1 Posted : Friday, 19 May 2006 7:22:44 AM(UTC)
anyone know how to remove xy fairmont stainless trims from around the tops of the doors?whats the trick,thanks
#2 Posted : Friday, 19 May 2006 9:34:46 PM(UTC)
Tuff,
Off all things - i modified a a tool used for putting castrating rubbers on lambs - but in hindsight it would have been easier to start with circlip pliers. I added 2 x thin 5cm long piece of steel to the pliers and very slowing spread the trim
6pak Offline
#3 Posted : Monday, 22 May 2006 12:44:32 AM(UTC)
6pak
Hi, I used a type of spatula that is used by dentists for mixing plaster when they take moulds. It's about and inch wide and has a rounded end with a curve in the blade. I used this to gently lever the trims off the plastic retainers. The retainers will
