308hjute Offline
#1 Posted : Wednesday, 31 May 2006 5:07:16 AM(UTC)
308hjute
G'day all,
Spent a lovely couple of hours in the shed last night with the quadrajet down to it's undies again.........
Had a bit of a splutter Sunday, then broke down badly Monday morning trying to merge into 90kmh traffic. Normally this thing runs as sweet as and just scoots when you boot it.
Found a bit of carbon in the idle ports (think that's what they're called) in the primaries, but other than that nothing that would indicate major filth. It is sucking this crap up from the EGR valve.
I ran it pretty low on fuel on Saturday, and it was a bit of a bitch to start Sunday morning. Backfired through the carb, then took a fair while to fire up. Normally it kicks first turn.
Anyway, put the carb back together and went for a blat around the block, and it was still missing/breaking down under hard acceleration uphill.
Only thing I can think of is the s***ty cheap fuel filter I am using (universal no name brand). It looks clean, but how sensitive to crap are these things? And what suggestions for a brand of fuel filter does everyone have?
Kev
BigMo79 Offline
#2 Posted : Wednesday, 31 May 2006 8:24:08 AM(UTC)
BigMo79
gday
I had the same sort of problem with an old holley i had...it would run like a dog and stall whenever i backed off the throttle, i was forever stripping it down and blowing out carbon and crap. I went through a few of those cheap plastic fuel filte
#3 Posted : Wednesday, 31 May 2006 7:28:04 PM(UTC)
You can also use a z200 fuel filter. These filters are designed for EFI systems so they have a finer filter medium but they work well on carb systems.
308hjute Offline
#4 Posted : Monday, 5 June 2006 4:21:32 AM(UTC)
308hjute
Since I posted originally, have had a couple of developments. Put a new fuel filter in, didn't make any difference. Changed the needle and seat for another good one I had in the shed. No difference.
Decided this morning to grab another quaddy my brothe
#5 Posted : Monday, 5 June 2006 8:05:15 AM(UTC)
.........If not, you're walkin' :D
Good to see you managed to diagnose it, although it was a painful process!
A lot of people aim to achieve nothing in life - and h
308hjute Offline
#6 Posted : Monday, 5 June 2006 3:48:55 PM(UTC)
308hjute
No, not quite Mick, have the Astra as backup ;-).
Spent half of yesterday with my mobile ready to dial your number though....
Kev
This page was generated in 0.114 seconds.
