#1 Posted : Friday, 16 March 2007 1:04:13 AM(UTC)
Hey there just a quick one my vr keeps blowing fuses everytime I use the central locking, I dont use the button on the remote as the battery is flat on it. So everytime I lock the door on the passenger side with the key turn it blows fuses just started doing it out of the blue. when I turn the key on the drivers side it just manually locks and all the other locks still stay unlocked so I have to lock all the doors manually it sux and is frustrating as when the fuse blows it shorts out the power windows and the stereo and help would be great thanks.
#2 Posted : Friday, 16 March 2007 9:18:10 AM(UTC)
If the fuse is blowing when you trigger the central locking (CL) power, then the power line is earthing somewhere. The earthing will be somewhere btwn the fuse panel and the lock. Most likely one of the CL cables has worn thru enabling the bare wire to to
This page was generated in 0.104 seconds.
