#1 Posted : Tuesday, 6 June 2006 7:37:00 AM(UTC)
Am just starting a project on a WB ute and wish to put a GTS dash into it. Just wondering what exactly I will need to purchase and do to transfor the original interior into a GTS interior with least hassles. Thanks to anyone that can help
#2 Posted : Tuesday, 6 June 2006 7:22:14 PM(UTC)
HZ and WB GTS dashes are the same. Only difference in the dash area is the blinker mechanism and the body harness. This is because WB's have reversing lights, and the HZ uses the blinkers for this purpose which is facilitated in the blinker mechanism. The
#3 Posted : Wednesday, 7 June 2006 8:33:14 AM(UTC)
Thanks for that info. I will still need to purchase a complete GTS dash complete with the gauges, wiring loom for the dash, Rear supporting frame for it or will a HZ, WB GTS dash bolt onto what is already there. First time doing this so all help is apprec
#4 Posted : Wednesday, 7 June 2006 5:35:12 PM(UTC)
The frame should be the same. Just be careful with some WB screws as some changed to metric at some stage but I think the dash stuff stayed the same as HZ.
