shouldntastarted Offline
#1 Posted : Friday, 16 March 2007 10:51:15 AM(UTC)
shouldntastarted
Did a search and didnt find what i want to know. I am in the process of upgrading the front brakes in my HX one tonner and will need to upgrade the master cylinder. Now i know WB ones are a common use but what other models/brands and sizes can be used. Is it just the master cylinder itself that is replaced or do you slot in a new booster etc to match? I will be using VX disks and calipers and have drum rear. Any ideas on cost and where to obtain the new master other than the wreckers?
Cheers for the help.
Scotty.
The mind is like a parachute! It works far better when open!
#2 Posted : Friday, 16 March 2007 11:31:17 AM(UTC)
Hi Scotty,
I don't know the whole answer to your queries, but there are some things to be careful of when trying to slot a WB master into an HX.
The WB master's mounting bolts are at an angle whereas the HX ones are horizontal so you'd also need th
HZute-efi-VS5L Offline
#3 Posted : Friday, 16 March 2007 5:58:59 PM(UTC)
HZute-efi-VS5L
Hey Scotty.
You only need a 1" master cyl for the vt/vx/vy brakes. These are still available new??? From the likes of repco etc????
I have used a corvette master cyl myself. its 1-1/8" bore like Dave said. you will not be able to use the corve
www.stickthisdecals.com.au
stopgo Offline
#4 Posted : Saturday, 17 March 2007 8:23:14 AM(UTC)
stopgo
$300 for the C3 vette master will still be cheaper and easier than finding and rebuilding a WB booster and new master , changing piping etc
The 1 1/8 master would be better for those calipers you plan to use
I wish you luck making them fit
