jayHK69 Offline
#1 Posted : Saturday, 17 March 2007 2:01:48 AM(UTC)
jayHK69
hi, i`ve just bought a hei dizzy to put into hk 307 can i run it without any mods or do i need to run a relay ? thanks in advance
#2 Posted : Saturday, 17 March 2007 3:07:33 AM(UTC)
My personal recommendation where HEI distributors is concerned is to run the relay and be done with it, not only because some ignition systems run a resistance wire to the original coil which needs to be bypassed but because you will then be giving your s
