#1 Posted : Saturday, 17 March 2007 8:16:31 AM(UTC)
Anyone know what the correct plug gap is using a msd 6al with 308 red motor? The plugs are standard v8 bosch. Cheers!
Sandman Offline
#2 Posted : Sunday, 18 March 2007 12:51:10 AM(UTC)
Sandman
With an MSD there is no set plug gap, as it depends on how the engine is set up eg comp ratio, fuel system etc.
Because an MSD increases the spark voltage it will jump a wider gap, so you could probably go out to .045"if the engine is reasonably std.
I
