#1 Posted : Friday, 16 June 2006 12:36:52 AM(UTC)
im going to get a blue 202 to replace the red 173 in my LJ torana. will the trimatic that is sitting behind the red 173 bolt straight up to the blue 202?
#2 Posted : Friday, 16 June 2006 1:16:21 AM(UTC)
Hi Quadzilla.
Yes, the Tri-Matic will bolt up, no problems.
You will have to check 3 other things though.
1. You will need to fit the Red motor water pump, because the Blue motor pump is too long & will be too close to the radiator core.
2. Yo
#3 Posted : Saturday, 17 June 2006 5:34:49 AM(UTC)
if the engine had a manual box behind it, do i have to get other parts for the tri matic to bolt up?
1. remove fan and install thermo fan?
2. can i remove the sump from the red and will it bolt up to the blue? to fit to the lj
explain minor wiring pl
#4 Posted : Saturday, 17 June 2006 8:44:12 AM(UTC)
The sump will bolt straight in. Remember to change the inside oil feed pipe as well,thermo fan is not essential, to fit the auto you have to remove the pilot bearing in the back of the crankshaft.
IMPORTANT when fitting the box make sure you rotate the t
#5 Posted : Saturday, 17 June 2006 8:45:55 AM(UTC)
Ha actually i just realised you already have the trimatic so all the wiring bit is not necessary.
#6 Posted : Saturday, 17 June 2006 10:43:00 PM(UTC)
thanks. it kinda sounds easy enough. although i know the easy jobs can become very difficult easily if you dont quite have an idea of what you are doing.
#7 Posted : Sunday, 18 June 2006 2:44:21 AM(UTC)
Hu Guys.
The wiring that I was referring to is the change from the Red motor's points ignition to the Blue motor's HEI electonic system.
Alternator & starter will basically the same depending on whether you are using an internal or external type vol
#8 Posted : Sunday, 18 June 2006 2:51:37 AM(UTC)
the varajet carbie is going. im thinking of rebuild the blue block, chuck on the 9 port YT head (with water gallery mods)have never seen a 12 port YT head for sale, with a crowe 35667 cam, extractors and a 390/465 holley, straight cut timing gears (always
peter_flane Offline
#9 Posted : Sunday, 18 June 2006 4:36:36 AM(UTC)
peter_flane
Yella Terra make new 12 port heads. They are not reworked or ported originals, they are new cast 12 port with excellent porting that is superior to original. So you will easily find a YT 12 port head for sale.
#10 Posted : Sunday, 18 June 2006 7:16:03 AM(UTC)
really?
u can buy 12 port YT heads for a 202. only seen 9 ports.. or are these still made by YT? cus the 9 ports arent
#11 Posted : Thursday, 22 June 2006 6:06:02 AM(UTC)
ahh too good. i emailed Yella Terra and they replied yes to 12 port heads @ $1155.45 inc gst. time for me to start saving
#12 Posted : Saturday, 24 June 2006 12:21:45 PM(UTC)
Fit a black head they are nearly as good. All you need to modify is drill a few new holes in the block line it up with a black head gasket and it will show where the holes go. block the old holes up. Far cheaper.
#13 Posted : Saturday, 24 June 2006 12:23:24 PM(UTC)
Take 40 thou off the head bring the compression up and run premium. more than 40 and the rocker angles are a bit iffy.
#14 Posted : Monday, 28 August 2006 8:24:07 AM(UTC)
fit a carbed or injected blackhead..which one?
#15 Posted : Monday, 28 August 2006 8:51:25 AM(UTC)
Duzn matter the only difference between the heads is the carby one has inlets for the emission control air pump just plug them off.
If you are planning major porting these ducts for want of a better word may mean the walls are a bit thin but I haven't re
Guest (7)
This page was generated in 0.153 seconds.
