#1 Posted : Friday, 16 June 2006 5:53:47 AM(UTC)
First time user of this site so I hope you guys can help. The story goes like this... I'm restoring a HQ GTS/4. She's been stripped down to the shell and re-painted. I pulled the engine out - a baby 253 and went about pulling her apart. I put new conrod bearings in but not crank bearings as I couldn't get the balancer off, put her back together and dropped her back in. I got the electrics re-installed (original wiring), got new plugs, leads, coil, battery leads, rotor and dizzy cap. I also changed over the 2 barrel strommy for a 4 barrel quady (bought that off ebay which might not be the greatest idea). Problem is that although the car starts most times- takes a few pumps of the accelorator, she runs rough and backfires out the carby. She also appears to be running rich. I've had the timing light on it and I've got her to run on the mark most of the time but the light seems to cut out rather than give a smooth shot. The mark also moves up and down and not constantly on the mark. I haven't had her tuned professionally yet as I've been trying to get rid of the backifire first. Going crazy so any ideas would help.
trubluhq Offline
#2 Posted : Friday, 16 June 2006 8:50:15 AM(UTC)
trubluhq
Firstly...now its got a Quad, and not a WW did you re-jet the Quad for a 253 ? Where does the fuel line come in from, side or the front of the quad ? What are you main jet sizes, and the skinny primary rod sizes ?
If you are running 308 jets it will r
#3 Posted : Saturday, 17 June 2006 1:17:09 AM(UTC)
Thanks John,I'll need to get the numbers for the jets,the rods and the quaddy. The fuel line comes in from the side not the front. The car is a manual and i didn't block of the dizzy. The carb has a manual choke if that helps. Any idea what the ideal jet
trubluhq Offline
#4 Posted : Saturday, 17 June 2006 4:50:29 AM(UTC)
trubluhq
hi HF,
A 308 runs 76/77 mains. Yours should be 70 or less. You need to ensure whether u have a manual or auto carby as the vacuum porting is different. The 703xxx or 704xxx will tell us. Always tune the QUAD HOT and with teh dizzy port on the carb bloc
trubluhq Offline
#5 Posted : Saturday, 17 June 2006 7:35:43 AM(UTC)
trubluhq
ALSO - make sure you have a working thermostat. It makes warm up time, economy and performance improve - heaps.
John
#6 Posted : Tuesday, 20 June 2006 2:56:31 AM(UTC)
Thanks guys - I've got the numbers now. The jets and rods that came with the carb are 76 jet and 47B rods. I got an old carb with 67 jets and 41J rods - not sure if any good. The carb number is 7043284 which I think is for an auto (after some looking on t
#7 Posted : Tuesday, 20 June 2006 5:24:19 AM(UTC)
Does the car run smoothly atall, i rebuilt a 308 and i was a tooth out on the timing for the distributor and it run ok but backfired alot
I love my 1 tonner
#8 Posted : Tuesday, 20 June 2006 5:31:07 AM(UTC)
Car doesn't run smoothly and is hard to start. Seems to be tempermental - sometimes she'll start and other times I just give up. I'm sure it must be the carby but not sure what else to check to confirm. Also I can't get her to accelerate or get the revs u
Munromad2004 Offline
#9 Posted : Tuesday, 20 June 2006 5:41:25 AM(UTC)
Munromad2004
Your carby (7043284) is originally off a 1973 Holden V8 and is designed for a auto transmission.
#10 Posted : Tuesday, 20 June 2006 5:49:39 AM(UTC)
Does that mean the carb won't run on a manual or does it need to be adjusted to suit a manual?
#11 Posted : Tuesday, 20 June 2006 7:23:13 AM(UTC)
hey holden fan , I think you should start from scratch, as Boswick said you should recheck dizzy initial timing ,firing order, also I think if you dont know the history of the carb it needs to be reconditioned , trubluhq has given jet/ needle details .A f
trubluhq Offline
#12 Posted : Tuesday, 20 June 2006 6:09:25 PM(UTC)
trubluhq
Hi Holden fan !
You are running 308 jets ! WAY TOO RICH. Good for SLR5000 but not a 253 !
Get some 67-68 mains. The Rods are fine at this stage.
Cheers John
#13 Posted : Tuesday, 20 June 2006 11:20:20 PM(UTC)
Thanks for the advise guys. Can anyone give me a name of a good carby rebuilder in south-west sydney? Cheers.
#14 Posted : Tuesday, 20 June 2006 11:44:38 PM(UTC)
He's not in SW Sydney but take it to Dr Terry's Workshop in Auburn (I think). You can E-mail him through his profile.
Cheers...Dave
trubluhq Offline
#15 Posted : Wednesday, 21 June 2006 5:30:36 AM(UTC)
trubluhq
You can buy the jets you need for around $12.00 new. Just change the mains...simple. The assumption is you can disassemble and reassemble the thing. There are so many guys that cant !!
Most of the carbies I have played with via Ebay already had a kit t
#16 Posted : Wednesday, 21 June 2006 7:11:37 AM(UTC)
Thanks guys I appreciate the info. Liverpool or Auburn will do just fine. I'll give them a call and see what happens. I got a quote from a guy out Mortlake NSW the other day and he quoted $250 to put a kit through with parts extra. A bit rich I thought...
KiwiHQ Offline
#17 Posted : Wednesday, 21 June 2006 5:12:25 PM(UTC)
KiwiHQ
If you change the primary mains should you change the rear needles as well? I presume that the main and rears are paired somehow?
Rock n Roll
Rock n Roll
trubluhq Offline
#18 Posted : Wednesday, 21 June 2006 8:29:31 PM(UTC)
trubluhq
Ok..the main fuel circuit consists of 2 things - a main jet that screws into the base, and primary rods (skinny brass things. A 253 will run Ok if you change down the mains - the screw in things. Dont change the brass rods - well not just yet. Lets get ov
KiwiHQ Offline
#19 Posted : Wednesday, 21 June 2006 10:39:11 PM(UTC)
KiwiHQ
Ok next question is for a 253 what is the correct size jet? I have read 67-70 odd. Can anyone narrow this down any or is that size range close enough?
thanks
Rock n Roll
Rock n Roll
trubluhq Offline
#20 Posted : Thursday, 22 June 2006 3:36:17 AM(UTC)
trubluhq
Hi Kiwi,
I dont have any specs on it. I can tell u what a 308 is, and I know how low a 253 can run ! And run fine too. But the 76/77 range is WAY too rich for a 253.
I all depends on how much GO you want out of the 253. What cam, exhaust, ignition
