Sandman Offline
#1 Posted : Sunday, 18 June 2006 2:15:51 PM(UTC)
Sandman
I put a engine out of my HQ in a HJ. I left the senders for the temp and oil pressure gauges in the engine and when I put it in the HJ, I fitted a HJ premier dash with temp and oil perssure gauges.
But they aren't working. Are HJ senders different from HQ's.
(Before anyone asks, they are senders for gauges, not warning lights)
#2 Posted : Monday, 19 June 2006 4:41:18 AM(UTC)
Yeah mate the senders/gauges work opposite in a HJ from HQ, I found out the hard way, you will need part no. 9932442 oil presure sender, rare spares have 'em, not sure about the temp sender no.
Cheers Nathan
Sandman Offline
#3 Posted : Monday, 19 June 2006 8:45:27 AM(UTC)
Sandman
Thaks mate, I thought I had done some bad wiring, but thats exactly what they are doing. working backwards.
#4 Posted : Monday, 19 June 2006 10:37:52 AM(UTC)
That's interesting. The Qute had one of the triple gauge clusters in it when I bought her with all the gauges working. When I put the WB Stato dash in her, the senders worked the WB gauges just the same...
Cheers...Dave
ozjason Offline
#5 Posted : Monday, 19 June 2006 6:44:51 PM(UTC)
ozjason
Might be one of those early/late HQ things, Dave? Is your HQ a late HQ? If so, it might explain why it works with the Stato dash. Maybe Sandman has an early HQ engine, before the change.
Remember the issue I had a few months back fitting an early tr
#6 Posted : Monday, 19 June 2006 9:20:36 PM(UTC)
HD to HQ, WB Satesman, HB to LJ Torana and VB to VK Commodore use one sender, and HJ to HX and WB with GTS dash and LH to LX use the other. I am unsure which one the UC uses
#7 Posted : Tuesday, 20 June 2006 6:19:58 AM(UTC)
Thanks Warren, that explains it :-)
Cheers...Dave
Guest (5)
