You are a member of these groups:: Guests
I am not overly interested in having a genuine GT coupe at all, but i would absolutely love an xb i could totally modify and go to town on.
i was wonmdering whether or not the xa / b/ c sedans all ran the same chassis? and if you can just sit a coupe shell onto a complete sedan chassis or whether or not you have to do a complete driveline swap
my idea was to buy an xa sedan to drive for now, and in the mean time organise a decent xb shell, and get it right upto scrathch the way i want it??
will this work? if i use an xa chassis i should be able to modify and get alot more out of this motor than in an xb?!?!
thanks ben
Hi Ben. The XB falcon is a unitary construction vehicle and doesn't have a separate chassis. The driveline from a sedan should swap into a coupe although I'm unsure about tailshaft length as I'm not too sure if the wheel base is the same. Cheers
Sedan and coupe share the same chassis. The running gear, including the tailshaft is a straight swap. Fairlanes, LTDs and wagons have a longer chassis so have a longer tailshaft and handbrake cable. As for bolt on panels, from the front windscreen back
so im up for a lot of time and ****ing about to get a coupe upto nice scratch and a lot of dollars, as it isnt really possible to just body swap....
bugger
I think what Paul351xb means is that both the sedan and coupe share the same wheel base and not the same chassis. As stated in an earlier post, there isn't actually a chassis on these vehicles. The body actually forms the chassis. The best you coul Edited by user Tuesday, 20 June 2006 5:43:20 AM(UTC)
| Reason: Not specified
Thanks Munromad, that is what I was trying to say. Just didn't say it very well. Not many people realise this but even the windscreens on the coupes are a one off. They only fit the hardtops and Landaus ( which is a hardtop shell anyway ). The wipers
um.... this may be sacreligious to some, but how hard would it be to fit a xb honeycomb grille to an xa?
ah bugger it, how hard is it to make an xa look like an xb... i just want to be able to have an XA to stay away form the pollution laws and ****, however they just havent got the same classic style as XB's.
so hard would it be to fit the different bonn
You can bolt the XB front onto an XA no worries. Might be a little bit of mucking about with the bumper brackets and a few other little things but nothing that can't be sorted out. With the coupes the XA tail lights will slot straight in. With the sedan
Here's an idea Ben,
Stick with your XA front end and give the XB grille to me. :-)
I could do with one of them.
