#1 Posted : Monday, 19 June 2006 7:36:57 AM(UTC)
Hi,
Does anyone know if the VN wheel stud pattern is the same as the VT stud pattern?
#2 Posted : Monday, 19 June 2006 7:50:22 AM(UTC)
yes
#3 Posted : Monday, 19 June 2006 8:11:46 AM(UTC)
But some of the old VN stuff might have trouble getting around some of the bigger brake setups on the VT,VX.......
Edited by user Monday, 19 June 2006 8:13:20 AM(UTC)  | Reason: Not specified
#4 Posted : Monday, 19 June 2006 10:39:25 AM(UTC)
And...the VT has a bigger centre-bore on the wheels to clear the bigger wheel bearings...
Cheers...Dave
#5 Posted : Monday, 26 June 2006 5:21:11 AM(UTC)
VN-VS centre hole is 70mm
VT centre hole is 71.5mm
You need to use centering rings to ensure the weight of the vehicle is taken on the spigot & not the studs (as they will break).
VT offset is also different - more positive, so the entire wheel mov
