prem Offline
#1 Posted : Wednesday, 21 March 2007 3:45:43 AM(UTC)
prem
CAN ANY ONE TELL ME IF IT IS EASY TO PULL THE AXEL HOUSEING OUT OF A SALISBURY DIFF SO THAT I CAN CHANGE LEAF TO COIL EASY....AND DOSE AND ONE KNOW HOW MINI SPOOLS ARE INSTALLED
Sandman Offline
#2 Posted : Wednesday, 21 March 2007 4:14:48 AM(UTC)
Sandman
What do you mean?? Change leaf to coil easy!!!
Are you putting a ute diff in a sedan??
Mini spools go in place of the stars gears. On a salsbury you have to use a LSD hemishere as a mini spool won't fit in an open centre.
Word of warning!!. If your p
#3 Posted : Wednesday, 21 March 2007 5:11:58 AM(UTC)
<I>Word of warning!!. If your planning on driving around the street with one, be aware that it will ALWAYS spin one wheels on turns as a mini spool locks both wheels together.
</i>
another word of warning, locked diffs are illegal on the str
#4 Posted : Sunday, 25 March 2007 3:12:21 AM(UTC)
Change Diff from Leaf to Coil Springs..????
I have modified heaps of coil spring Diffs to suit Leaf springs, They are EASY..!!
I do that because coil spring diffs are CHEAP
Leaf Spring Diffs from Holdens are 2-3 times the price.
I would never b
