prem Offline
#1 Posted : Wednesday, 21 March 2007 3:53:31 AM(UTC)
prem
I WENT TO A DYNO DAY AND FOUND OUT THAT THEY WHERE DOING IT IN 3RD GEAR WHY IS THIS AS I THOUGHT IT WOULD OF BEEN 4TH GEAR (CLOSER TO 1:1 RATIO) TO CANCLE DIFFERENT 3RD GEAR RATIOS.
#2 Posted : Wednesday, 21 March 2007 4:13:16 AM(UTC)
should have done it in all gears .
What did they charge you????
peter_flane Offline
#3 Posted : Wednesday, 21 March 2007 4:14:12 AM(UTC)
peter_flane
Even in top gear you would get different ratio's through the diff, and different wheel speed based on the diameter of the tyres. I think it would be an interesting question to ask the dyno operators. What gear would they use on a three speed automatic?
#4 Posted : Thursday, 22 March 2007 4:52:30 AM(UTC)
so is it ment to be done in 4th gear to get top read out
peter_flane Offline
#5 Posted : Thursday, 22 March 2007 8:11:53 AM(UTC)
peter_flane
The last car I had done on "shootout" mode was done in third gear for a 4 speed vehicle!
