RobertM Offline
#1 Posted : Wednesday, 21 June 2006 3:12:32 AM(UTC)
RobertM
Hi guys i am putting new carpet (loop pile ) in my 67 mustang and am after a few hints, floor is good except one rear pan has slight rust, ive cleaned everything up and there was lots of hard putty like stuff ( joint sealermaybe?). question is what should i paint metal with to help with rust prevention,should i use a new joint sealer , what should i use for sound and heat proofing ( there was lots of hession fibre matting under old carpet,fitted and about half inch thick but i doubt i can find a replacment like that,so maybe carpet underlay or foam? i thought maybe some sort of thick coating like waterproofing compound or sound deadener may work .Sorry about the long winded question,
6pak Offline
#2 Posted : Wednesday, 21 June 2006 5:45:55 AM(UTC)
6pak
Hi Robert, You need to replace the joint sealer with sikaflex or similar. If the rust is just on the surface use Ranex rust converter and then prime and paint it. Automotive carpet places also sell various types of underlay ranging from the rubber type
#3 Posted : Wednesday, 21 June 2006 6:43:46 AM(UTC)
no apparent reason for the rust, its not bad but there are a few pin holes over an area the size of a hand,i was hoping not to cut it out but to kill it and patch it with a liquid metal or some such pour on and spread product. should i use th
6pak Offline
#4 Posted : Thursday, 22 June 2006 9:19:40 AM(UTC)
6pak
Hi Robert, If there are pinholes it's bad. The metal around those pinholes wil be paper thin and you'll be able to punch a hole through it with a screwdriver. Liquid metal will plug the holes but it wont address the problem of the weakened floor pan. As
#5 Posted : Friday, 23 June 2006 12:16:38 AM(UTC)
Your right about the thiness but its not over a big area just a hand size, thats why i was hoping for a liquid type thing to increase the thickness of that area. if i cut and replace i will do the whole floor pan on that side, not real sure where the wate
