#1 Posted : Friday, 23 June 2006 8:21:59 AM(UTC)
Can someone help, I'm considering buying a cross member but not sure if its for a sedon or one tonner. I own a HQ one tonner and want to know if the below specs are for a one tonner or not?
It is 1365mm long end to end
Please help
Rick
#2 Posted : Friday, 23 June 2006 10:49:36 AM(UTC)
You should be able to measure the space in the one tonner you have and that will tell you if it will fit in there or not. There is one of them for sale on ebay.
#3 Posted : Saturday, 24 June 2006 5:13:34 AM(UTC)
the cross member should be the same width accross the range, it is the tailshaft for a tonner that is longer than the rest.
#4 Posted : Saturday, 24 June 2006 6:29:11 AM(UTC)
I believe the commercials have a different length cross member to the passenger cars, but longer or shorter, I do not know.
#5 Posted : Saturday, 24 June 2006 8:23:35 AM(UTC)
Hi Monaro202.
That is not correct, the HQ-WB crossmembers for the commercials are a few inches shorter than the passenger cars because of their mounting method to the chassis. The passenger car crossmembers fit inside the chassis rails, while the comme
#6 Posted : Wednesday, 28 June 2006 6:14:14 AM(UTC)
yes you are spot on Dr Terry, i should've looked out my back window at my newly galvanized tonner chassis... thank's for correcting me, there is nothing worse than wrong or disinformation...
kevin
Guest (5)
