ianb Offline
#1 Posted : Friday, 23 June 2006 5:31:48 PM(UTC)
ianb
hi, can anyone tell me if the doors on all hj-hz are all the same. i need a door for my hx sandman van and was wondering if i need a door from another van/ute or if a sedan door will fit.
also what wheels will fit on the hx, can i fit any later holden wheels or is it a big job.
thanks
ian.
#2 Posted : Friday, 23 June 2006 6:01:53 PM(UTC)
Hi Ian.
The front doors are all basically the same fron HJ to HZ, even the HQ ones will fit, it's just that their internals are different.
The other difference that doesn't effect interchangeability is the introduction of the internal side impact b
#3 Posted : Friday, 23 June 2006 8:23:57 PM(UTC)
Hi Ian,
If you are asking whether you can fit Commodore wheels to your HX, the short answer is no, not without quite a lot of work. The stud pattern, while close, is different as is the offset.
Either look for HQ - WB wheels or Chev wheels as they s
ianb Offline
#4 Posted : Saturday, 24 June 2006 5:48:27 AM(UTC)
ianb
thanks for the replies, so i can look for sedan doors aswell if ute or van doors seem thin on the ground.
#5 Posted : Saturday, 24 June 2006 7:40:21 AM(UTC)
Yes...Sedan, Stato, Wagon, Ute, Van, Tonner front doors are all the same.
Cheers...Dave
This page was generated in 0.146 seconds.
