#1 Posted : Thursday, 22 March 2007 1:49:15 AM(UTC)
while checking my brake pads on my hq ute pbr cast iron calipers i found the out side left down to almost nil while the inside left and right hand pads only half worn what causes this ? ps i recently had my rotars machined and fitted new bearings thanks and cheers
FastEHHolden Offline
#2 Posted : Thursday, 22 March 2007 5:55:45 AM(UTC)
FastEHHolden
Usually it is sticky slides that do that..when you replace the pads grease the pins of the slide.
