#1 Posted : Friday, 23 June 2006 9:22:21 PM(UTC)
Hi guy's, I am trying to confirm if the stubs in my spare HR disc brake front end are actually HR or Torana?
The part numbers on them are 26019 and 26020
If these are HR can anyone also give me the Torana numbers so I can I.D. them, I'm hunting around ATM for a better condition set of HR stubs so I can mount up the hopper's front brake commy kit.
The spare stubs are flogged in the bottom ball joint hole :(
Cheer's
edit: Anyone have a parts book that can I.D. the number's??
Would like the torana numbers so I can tell the difference as I don't want to put it all together only to find out I have the wrong stub's! + I have a few cars to look at and IF I come across either stub's in good nic I'll grab them..... but what's what? They look the same but not :)
life's to short not to be....
Edited by user Saturday, 1 July 2006 1:25:15 AM(UTC)  | Reason: Not specified
#2 Posted : Saturday, 1 July 2006 5:13:20 AM(UTC)
torana ones look diferent ,,they stick out a fair bit
hr ones are a 2 piece as well they have bolts around the out side so when you cange the rotors you keep the centre part
peter_flane Offline
#3 Posted : Monday, 3 July 2006 7:08:28 AM(UTC)
peter_flane
Torana stubs have a really big thread on the end where the nut goes on, same size as a HQ. Maybe 19mm thread. The oustide diameter of the nut is about 1 inch. HR has a smaller thread, maybe 16mm. Someone must have the actual sizes though. C'mon, help us o
#4 Posted : Tuesday, 4 July 2006 1:53:57 AM(UTC)
Thanks Peter,
I was thinking of the LC/LJ stubs and "I think" also LH and the first part of the LX run stubs that look very close to HR. Later LX got the HQ style and the bigger nut?? But yeah just unsure how similar they look but if they only run the 4.
This page was generated in 0.065 seconds.
