#1 Posted : Wednesday, 28 June 2006 10:23:39 AM(UTC)
just looking for some ideas .when turning right hand corners hard the old 202 stalls up like shes looking for fuel but runs fine as soon as the car levels out.I have tried a new carb with no change and thought the fuel pump might be the problem.everything is original except commodore electric dizzy and it dosnt happen turning left.any ideas would be much appreciated.
trubluhq Offline
#2 Posted : Wednesday, 28 June 2006 6:27:20 PM(UTC)
trubluhq
When car is cold, hot or always ? What fuel are you running ? Is there water in your tank, or carby ? Replaced the fuel filter ? Hows your float level ? Hows the idle mix ?
Dizzy unlikely issue..but happens on the RH turn sounds like float !
John
#3 Posted : Wednesday, 28 June 2006 9:33:42 PM(UTC)
thanks ill have a look at that. i just swapped carbs and hoped for the best.it does happen regardless of temp range.
bluHJ Offline
#4 Posted : Wednesday, 28 June 2006 10:16:25 PM(UTC)
bluHJ
I had that happen to me in an old XA but it was on left turns. I turned out to be a coil shorting internally.
#5 Posted : Wednesday, 28 June 2006 10:33:59 PM(UTC)
Check for wiring shorting on the steering column or possibly the alternator, starter or fusible link wires shorting on the LH upper control arm.
danny88 Offline
#6 Posted : Thursday, 29 June 2006 5:55:03 AM(UTC)
danny88
i had this happen to me your carby may be flooding might need a new float and also a carby kit
