jimbobhtute Offline
#1 Posted : Friday, 30 June 2006 9:32:05 AM(UTC)
jimbobhtute
Hello to all,
Just needing to know the rough price to either overhaul or replace the brake booster and master cylinder for a HT ute with disc front/back. Been told it is the 'monanro style' (the wider/deeper of the two). My current one is leaking which is causing some of the idling problems I have previously posted, and master cylinder on it's way out.
Any basic prices will start the thinking process.
cheers guys. james
1970 HT UTE
1970 Green HT UTE...
#2 Posted : Friday, 30 June 2006 5:26:29 PM(UTC)
There are two boosters oin the HT, power drum and disc. There is no special"Monaro" Booster.
The 4 wheel disc master cylinder should cost about $200 max to have recoed with stainless insert. I would expect about the same on the booster.
Warren
stopgo Offline
#3 Posted : Sunday, 2 July 2006 7:29:30 AM(UTC)
stopgo
Assuming the master is the original HT one but setup for disc then expect to pay under $200 to recon as mentioned with stainless sleeve
As for the booster
There are 3 of the big ones
1. VH316 has 95mm rear rod and sits on cantilever bracket (usually
jimbobhtute Offline
#4 Posted : Sunday, 2 July 2006 8:29:45 AM(UTC)
jimbobhtute
Thankyou stopgo & warren,
Do you know where I can locate the Part No# on the unit(booster) & also if you or anybody else knows where I can exchange these items in the wollongong/sydney area??? I am epecting places like Brake Pro to be a tad expe
#5 Posted : Sunday, 2 July 2006 8:34:52 AM(UTC)
Sydney area? only one place to go...Dr Terry's workshop...Bebco Automotive.
Cheers...Dave
jimbobhtute Offline
#6 Posted : Sunday, 2 July 2006 8:03:53 PM(UTC)
jimbobhtute
Thanks Dave, Where abouts are you Dr Terry??? And how much do you charge roughly???
#7 Posted : Monday, 3 July 2006 2:08:25 AM(UTC)
If you find a post or reply by Dr Terry, you can send him an E-mail by clicking on the second icon from the left in the top of his reply.
IIRC, his workshop is in Auburn. If you look up the whitepages for Bebco Automotive in Sydney, his phone number wi
Edited by user Monday, 3 July 2006 2:09:11 AM(UTC)  | Reason: Not specified
stopgo Offline
#8 Posted : Monday, 3 July 2006 6:41:18 AM(UTC)
stopgo
Booster part # is on the front cannister
Around the edge....... near the bonnet hinge area
Usually
jimbobhtute Offline
#9 Posted : Monday, 3 July 2006 7:27:41 AM(UTC)
jimbobhtute
Thanks guys will look...
cheers james
