#1 Posted : Monday, 3 July 2006 1:18:38 AM(UTC)
what would the cubic capacity of a VS commodore be if it had a 20 thou overbore? how do you work it out??
kevin
#2 Posted : Monday, 3 July 2006 2:45:18 AM(UTC)
You neeed to work out the standard bore & stroke, and use the formula pi x R squared. R is the radius (ie half the diameter of the bore).
That will give you the capacity of 1 cylinder.
The you do the same with the increased size.
Now subtract t
#3 Posted : Tuesday, 4 July 2006 8:21:06 AM(UTC)
Thank's...
#4 Posted : Tuesday, 4 July 2006 8:50:07 AM(UTC)
OK, here goes.
Bore x Stroke: 97.0 x 86.0mm
Capacity: 3791cc / 231ci
Banging it all out on the calculator I come up with around 41cc more for the overbore.
Which equates to approx 3832cc
This converts to approx 234ci
_____
