#1 Posted : Monday, 26 March 2007 5:32:07 AM(UTC)
hi, how much and how hard is too swap the transmission in a wb 1 tonner from a manual too a turbo 400? It has a 308 red engine and currently has a supra 5 speed trans in it.
#2 Posted : Monday, 26 March 2007 5:49:09 AM(UTC)
It's easy if the block is a TH block. If it's a manual or trimatic block it's not easy to fit a TH400. Check your block first. A trimatic block has the top two bellhousing bolts right up in the corners. A TH400/TH350 block has the top two bolts down about
HQ308 Offline
#3 Posted : Thursday, 29 March 2007 6:52:05 AM(UTC)
HQ308
Byron, will a VK/VL Trimatic bolt straight into an HQ?
#4 Posted : Thursday, 29 March 2007 7:40:31 AM(UTC)
Yes but you need to use a TH400 shifter (or a UC one) as the shift is on the left. Also check the teeth on the drive gear for the speedo as the wrong one will stuff up your speedo reading. I'm assuming you have a trimatic block too.
___________________
