RussVRute Offline
#1 Posted : Friday, 7 July 2006 6:56:10 AM(UTC)
RussVRute
G'day all,
I was wondering if the radius rod bushes (the front ones that mount to the chassis) can be changed easily, or is it a major job involving taking the control arms and everything off?
Any advice appreciated.
Cheers.Russ.
P.S. I will get a workshop manual for it eventually, but I need to find a good one, I had a look at a gregorys one, but I dont really think they are that good, can anyone tell me where I might be able to get a more comprehensive one? I have heard ellerys are a good one, but I have never seen them in any shops? advice on this would be appreciated too!
#2 Posted : Friday, 7 July 2006 7:38:48 AM(UTC)
Yep, you need to remove the control arms. I usually remove the control arm & radius rod together.
The bushes need to be hacked out - I cut as much rubber off the front as possible & punch them through, and then I draw the new ones in using a bit of p
#3 Posted : Friday, 7 July 2006 11:32:58 AM(UTC)
Hi Russ,
I have only looked at the HQ - HZ and VL Ellery's Manuals and they are an absolute load of garbage. They have LOTS of wrong information in them and they don't even mention important bits of the car. Gregory's Manuals have much better accuracy
Taz2 Offline
#4 Posted : Friday, 7 July 2006 4:48:38 PM(UTC)
Taz2
The only other way to go is to purchase the appropriate factory manual...but they aint cheap!!!
I think I got my genuine manuals from Pitstop books in Adelaide....from memory.
Cheapest option is the local library.....and photostat the relevant pages. Be
In thrust we trust
#5 Posted : Friday, 7 July 2006 5:54:05 PM(UTC)
Or you could ask nicely on here for scans of the relevant data if someone has a factory manual & won't mind doing it?
Russ, as you're a good contributor to the forum, send me an email (click on my name to go to my profile page, then click the email lin
