#1 Posted : Sunday, 9 July 2006 7:55:06 PM(UTC)
I have a white foam jack box which was supposed to be Holden of some description as I was told ,
it is longer than the HQ GTS one and not as wide it would fit in the rear side compartment of a statesman I am guessing as its to long for a sedan. The jack is identical to an original HQ jack with ratchet ,the wheel nut remover doesn`t have the curved end. any ideas or did some statesmans have these?
#2 Posted : Monday, 10 July 2006 12:41:48 AM(UTC)
Hi cloudy.
Can you post a picture, AFIAK all the HQ GTS/Statesman type foam boxes are the same & all the later models use a bumper jack.
They did use them in Camira wagons etc, these were longer, so it might a late model small Holden of some type.
trubluhq Offline
#3 Posted : Monday, 10 July 2006 3:22:57 AM(UTC)
trubluhq
if you look at the pic on the left...you will see the foam box.
John
classic oz wreck Offline
#4 Posted : Monday, 10 July 2006 5:58:28 AM(UTC)
classic oz wreck
wb statesman also had the foam box...but that isnt it...
www.classicozwreck.com.au
#5 Posted : Monday, 10 July 2006 4:03:56 PM(UTC)
I`ll get a pic soon
#6 Posted : Monday, 17 July 2006 3:41:34 AM(UTC)
Greg is checking monday , but he thinks its WB statesman from the pics I sent him.
#7 Posted : Friday, 21 July 2006 4:07:06 PM(UTC)
The foam jack box is from a WB statesman , thanks to Greg at classic oz wreck.
