Jvanner Offline
#1 Posted : Wednesday, 12 July 2006 10:29:12 PM(UTC)
Jvanner
hi guys.just want to ask alittle on the struts on the new commodores. Like the old Commodores with the 3 bolts on the inner guard,the new commodores only have one centre nut.just undo the nut and the tower will fall away? on the VX do i need to undo the ball joint or will the lower control arm fall lower enough for the strut tower to clear the guard. when i get this far what will i face then. do i need to comress the springs before i remove the strut tower. or can i do it later when its out of the car? any info will be appreciated.....Jamie
#2 Posted : Thursday, 13 July 2006 3:00:58 AM(UTC)
Hi Jamie.
If you are trying to just replace the struts, it's an easier job than the VB to VP Commodores. If you remove a front wheel you will notice that the strut has 2 bolts holding the bottom of the strut to the front stub axle. You just remove thos
Jvanner Offline
#3 Posted : Saturday, 15 July 2006 4:14:30 AM(UTC)
Jvanner
thanks for your help Dr Terry
