#1 Posted : Friday, 14 July 2006 9:47:11 AM(UTC)
Hi guys,
I have a hz sedan to wreck and was thinking about keeping the chassis to use for another project down the track (old f100 or chev truck sort of thing)
Would this be a good thing to keep or do i need a ute chassis?? or are they the same setup?
All help appriciated, thank you
#2 Posted : Friday, 14 July 2006 9:57:30 AM(UTC)
HQ - WB sedan/wagon/Stato chassis are a ½ chassis. They bolt to the main body of the car at the firewall with legs going back under the body also attached to the body by bolts. The rear suspension is mounted onto the actual body shell.
The Utes and Van
#3 Posted : Friday, 14 July 2006 6:09:20 PM(UTC)
As well as what Dave has said, the 1/2 chassis is identical to the front half of the commercial chassis, and it is welded to the rear 1/2. Plenty of smashed/cracked tonner chassis have been repaired this way in the past. A lot of 55-57 Chev's have also be
#4 Posted : Friday, 14 July 2006 9:48:20 PM(UTC)
Great, thanks Qute and Byron Rich. I think i might part with it though, she has a pretty straight body on her with limited rust, Might suit someone on here. will post in sale section if i decide to.
