how do you tell a turbo pattern 308
A picture tells a thousand words:  Cheers, Mick _______________________________________________________________ A lot of people aim to achieve nothing in lif |
so if vehicle was fitted with manual gearbox will i be able to fit turbo 350
Aussie 4 speeds are trimatic pattern, and a turbo 350 wont bolt up to one of them.
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
Aussie 4 speeds are trimatic pattern, and a turbo 350 won't bolt up to one of them.
what about using an adapter plate
You could, but its messy, and you need to use spacers on the flex plate/convertor bolts too.
The other option is to get the block redrilled to suit.
A lot of people |
You could, but it's messy, and you need to use spacers on the flex plate/convertor bolts too.
A lot of people |
You only have to be in front at the end of the race. |
Im looking for a trimatic 308 block, I have a Turbo block to swap.
Drop me an email if interested.
Where are you?
I'm looking for a trimatic 308 block, I have a Turbo block to swap.
Where are you?
i have a 308 red trimatic patten witch is in a ute that i am driving at the moment but have to take it out and put a turbo in it to fit my supra 5 ,willing to swap where are you located
why not just change bell housing.....my supra came with a double drilled bell housing.....there about $320 plus postage......
Prem, I am located in Adelaide. I am interested in the 308. Email is [email protected]
