#1 Posted : Thursday, 29 March 2007 3:55:06 PM(UTC)
I have a VR V6 recently the engine light come on after driving for a while , I had it tested and the oxy sensor was the fault , it was reset but is coming back on ,but this is only when running on LPG not petrol. I can drive about 90klm with no light another trip of say 5klm it will come on any ideas?
It has new airfilter,plugs and leads, when I did the plug change one plug had excessive fuel deposits on it (centre plug left side) , the others looked normal.
#2 Posted : Friday, 30 March 2007 9:21:05 AM(UTC)
Cloudy. It could be a coilpack going out and not putting out enough spark on that cyl.A spark tester may show it up if it is.Just something to check? and general warning to those that dont know. Dont hold on to a plug lead of a coilpack fitted car when it
Rhys Offline
#3 Posted : Friday, 30 March 2007 11:59:47 PM(UTC)
Rhys
Cloudy,
Some LPG conversions kits cut into each individual injector, and others cut into the main feed for the injector circuit. If you've got the individual cut-offs (usually 2 banks of triple harnesses for a 6), then its possible 1 of the 6 isn't op
#4 Posted : Monday, 2 April 2007 6:25:24 AM(UTC)
cheers for that.
